Latest post 09-13-2010 3:38 AM by DrDimitris. 1 replies.
Page 1 of 1 (2 items)
  • 09-12-2010 3:17 AM
    BV7-32 and HD broadcast problem
    My BV7-32(HD-Ready) is connected to an HD receiver (PACE HD831). I am receiving normally the HD channels, but yesterday one specific channel did not. The sound is coming but not the picture. I connected the receiver to other TV set, it works fine. I swapped the cables on my BV7 but nothing. i altered the menu on the receiver playing with the resolution (780p, 1080i)…nothing. After excluding all other possibilities i concluded that it is something with my panel. Has anyone encountered any incompatibility issues between his BV7 and HD channels? Maybe something with the channel's bitrate or something?
    Is there something i can alter in the Beovision's menu that it can fix it? It seems really strange that other HD channels play fine and this not.
    Any help would be appreciated.
    -Dimitris
  • 09-13-2010 3:38 AM In reply to
    Re: BV7-32 and HD broadcast problem
    I think it was too techie so i got no replies. Just for future reference. After extended search on the forum and many tests by me, i concluded that due to some peculiar reason BV7-32 SOMETIMES does not <<speak>> properly to HD receivers. This is solved by removing once the HDMI cable from the HD receiver and plugging it back. It has also been reported by forum member MERCATS here.
    -Dimitris
