Hello,
few weeks ago my HDR2 often interrupted records for no reason. My dealer had updated the software of the HDR2 but this did not solve the problem. Therefore the HDR2 was sent to Munich, where the harddisk was replaced. After that records didn´t interrupt any more.
But from that time I have a NEW problem:
If I program a timer record with my HD module, the HDR2 switches on the HD module at the programmed time, but does not set the right channel. The HDR2 records always the last channel of the HD module that was on before turned off the whole system. My dealer and the technicians in Munich have no idea, although they have already contacted B&O in Denmark.
I guess now it has something to do with the above mentioned software update of the HDR2! My dealer told me, that it´s not possible to downgrade the software. My HDR2 shows in the service menue (0-0-GO) the following:
H8 Information:
AP SW 3.6
AP Boot 1.1
IOP SW 22.0
Type No. 4643
Item No. 1464007
IOP SW 19856619
IC Information:
MSP 02070F48
HIP 09
HOP 0C
ML Information:
HW
ML 92.00b
MLBOOT 92.00c
STB TABLES 03.80a
STB Timer 0
Has anyone of you an idea if some verions are not actual or if any mentioned versions are not compatible? Or any other idea what to do solving the problem?
Any suggested solutions are welcome because of my despair!
Regards
Räuber
