Hello anyone I live in hope somone may be able to offer some advice
for the following fault on my beocenter 1 type 8523 which i obtained
from ebay as
spares /repair. All i have is the red stby light when i apply power no
responce via beo4 remote not even a blink from the red standby light. I
have been advised by the
previous owner that B&O have done an assesment on the item and
advised a PCB power supply fault, so to confirm this i removed the tube
neck pcb and
applied power and still only red standby led,  presumibly then that
would confirm the fault
is elsewhere perhaps on the power supply PCB4. There is some 380
voltage @ C4 on pcb4 and with other caps  however this varies wildly
from 170 -380, I have also checked for a  -8V  stby on pin 9 socket 514
of pcb 72  and nothing there, I have tried to find a wiring diagram for
PCB4  with no joy this site only has a block diagram for all the
various module
connections.  Does anyone have any idear were to
start looking for the fault and even a wiring diagram for PCB4 so i can
start
to enjoy watching this lovely TV.
Regards Maurice.
