Dillen:
Beovox S40 (and similar S35-2) are some of the best 2-way speakers from B&O.
I like their sound a lot and people who listen to them are often surprised to see that
they are in fact only 2-way.
White Beovox S40 is very rare to see - if original. A lot were painted but the original is thin laminate.
The value of the older things, generally, equals what people are prepared to pay.
White design generally goes a bit higher than wooden finishes and I've seen palisander
S40's go for something close to the amount you mention, so the price may not be unfair for
someone who really wants a pair like this. If you are such a person, I suggest you grab them
while you can.
Some Beovox S40 have foam woofer surrounds that will suffer from foam rot (it's repairable but
should cause a discount in the speakers price), others have rubber surrounds which will be fine.
Apprx. 50% chance of foam, according to my notes so worth checking.
Hi, Martin:
I finished the refurb of my S45-2s, and boy, oh boy, did your caps make all the difference in the world. I tried my old midrange, and it turned out it was fine afterall once the caps were replaced. I went ahead and permanently installed my old midrange and put yours aside for a spare.
I'm glad to hear the S40s receive the "Martin Seal of Approval." I just picked up a pair of these for next to nothing because the woofers need foam repair. I'm going to give that a go. I have a kit with new surround, adhesive, dust cap, and shims. Have read some of your notes on foam repair and watched a 20 minute video that came with a kit - looks like patience and a steady hand are the keys to success.
I haven't opened the S40s up yet. Will they likely need a cap replacement? Any other things I should look out for while I'm in there?
Rich
Current primary listening: SMMC20EN -> BG4002 -> BM4000 -> Beovox M70
