Ok, so the problem is that my turntable starts reeeeeaaaally slowly. When I push start-button, first it seems like the platter wouldn't turn at all, then it starts to gain revs really slow. after some 3-5 minutes it spins as it should (well almost, with pitch turned all the way up). The "gears" (small copper/brass cone in the end of motor's shaft and large rubberwheel the cone touches) are transferring the power nice and tidy. While TT is gaining speed, if I try to help it by spinning the record by hand, it won't help, the speed falls to where it was before I touched it. To me it seems like the motor would slowly gain it's right operating voltage, like it would be charging itself. When I flip the record or change the record, next time I push start, it will gain the right speed MUCH faster, but still a bit slowly... But if I let it be for some hours then it'll be way too slow again, like some condenser's would lose voltage or something...
http://www.danny.mcnulty.btinternet.co.uk/audio.html
It seems like this guy would be having the same problem.
