My Beomaster 8000 has recently started to get intermittemtly noisy in one channel. It usually starts after the amp has well and truly warmed up (well, the heatsinks run pretty hot). It's the same on all inputs - phono, tape, CD and radio. The noise sounds a bit like a poor connection and the signal will sometimes drop out completely. I've swapped the speaker connections from LS1 to LS2, the speaker cable, and the speakers themselves and the problem persists in the left channel. It doesn't occur with headphones at all which I suppose means its one of the power amps.
Any thoughts?
Cleve
