Latest post 07-04-2010 4:21 AM by Peter. 6 replies.
Page 1 of 1 (7 items)
  • 07-02-2010 5:18 AM
    Is it possible to TURN OFF 100hz on Beovision 7-55?
    Hi, I wonder if it is possible to turn-off 100hz on Beovision 7-55
    Regards
    Beolab 5 with sw 3.0,  BV7-55 3D without Bluray(MK II), Beolab 7-4, Beolab 4000 MKII, Beolab 3500, Beovox CX100, Beosound 9000 mkIII, Cabinett 2054, Beo4 MKII, Oppo BDP-93 Blurayplayer (B&O-version)
  • 07-02-2010 5:47 AM In reply to
    • Zoe
    • Not Ranked
    • Joined on 05-16-2007
    • Posts 5
    Re: Is it possible to TURN OFF 100hz on Beovision 7-55?
    BeoVision 7-55 is a 200 Hz TV and it is not possible to turn off
  • 07-02-2010 5:48 AM In reply to
    I think this one is actually 200-250Hz . I don't think you can - why do you want to?
  • 07-02-2010 7:32 AM In reply to
    Maybe it wont work to shut the 100hz off. BUT: BV 7-55 is a 100hz-screen and nothing else. In the tecnical specifications it says 100hz AND in the "customer meny" You can read "panel output" as 100hz.
    Regards
  • 07-02-2010 12:29 PM In reply to
    The Bv 7-55 is a 100/120 hz screen.
    Bv7-55 & Bv7-32...Blue,lab1's x4,Yes4Blue, 6000x4Blue,Beocom6000 Blue,Beo5.Oh what a Blue set-up & a Beosound 5...After all,its Bang&Olufsen!
  • 07-03-2010 5:23 AM In reply to
    A really interesting thread, but I don't know the answer.
    Astounded when I first saw the quality of Avatar on the 7-55, so as any decent human being would do I went out and bought the Samsung 55" panel with Freeview HD and 4 x 1.4 HDMI, 3D CAPABILITY via compatible player and so on.  £2300 seemed great value through the trade!
    Stated specs for this are 200hz Motion Plus, so maybe Samsung have added some electronic processing which B&O have not.  When I get back from a short break I will check to see whether Motion Plus can be turned off on the Samsung, and if so what the refresh rate is when it is off.  I would be very surprised if you can do anything with the B&O product without meddling in the Service Menu.
  • 07-04-2010 4:21 AM In reply to
    Had a quick flick through the service manual. The screen is 100/120Hz refresh rate - I had thought it was similar to the BV10 but was wrong. I cannot see any setting to turn off the 100Hz.
