        1st March February 2012
	    Latest post 06-26-2010 5:03 PM by  sodoi18. 3 replies.
								        06-25-2010 11:48 PM
									        sodoi18
								                - Joined on 02-06-2010
								                - USA
								                - Posts 194
										    Today i tried connecting beoport with the new version (5.0XX) of software
connect via ML to beolab 2000. I think i connected every thing correctly
 but still no sound
My Setup:
3.5mm laptop out to 3.5mm
beoport in, usb from laptop to beoport, ML from beoport to beolab 2000,
option 0
What is wrong here and could you please share details of
your similar setup with beolab 2000 and beoport.
My laptop is running visat sp1
									    Beovox RL 60.2, RL 6000, S45-2, CX 50, Cona, Beolink Passive, MCL2P, BM4500, Beosound 1, Beocenter 2500, Beolab 2500, Besound 4000, Beolab 4000, Beocom 6000, A8, Beosystem 1
									        elephant
								                - Joined on 04-16-2007
								                - Melbourne, Australia
								                - Posts 2,215
										    Re: Beoport with Beolab 2000
										    Test the BeoPort through its headphone jack then we will know whether you are getting the music as far as the BeoPort and therefore whether the problem is at the ML level or beyond
									    First B&O (1976) was a Beogram 1500 ... latest (2011) change has been to couple the BL11 with the BL6Ks *sounds superb*
									        sodoi18
								                - USA
								                - Posts 194
										    Finally got it going on option 2 and the beo4 controls the unit with N Music and N Radio veery well.
One big concern is on windows xp the beoplayer software does not allows the changes to opt in setting.
The advance setting tab is missing from setup config. However, the same setting is
Available when connected to a laptop with vista sp1
Does any one knows how to make option 2 as default for the beoport in windows xp
									        sodoi18
								                - USA
								                - Posts 194
										    Is it possible to edit the option settings for beoport using windows xp?
        Page 1 of 1 (4 items)
