I own a Beocenter 2300, bought somewhere mid nineties. It would seem it's getting a bit older, as I have a few small problems:
- the right light next to the cd is broken. Can I repair this myself, or should I take it to the shop?
- Every now and then, the sliding doors malfunction. When I wave my hand in front of the beocenter, the doors open, but the motors seem to keep on "pushing" the doors outward, even when they reach their open position. You can clearly hear the mechanism continue to run, until the system closes the doors again (after a minute or so, so the closing aspect is fully functional). This isn't a major issue, but I'm wondering if this isn't bad for the mechanism? Any advice?
- When pushing the CD button on the remote (beolink 1000), CD playback works properly. However, if you push the CD button on the beocenter itself, the display switches to CD mode, but it shows the <> sign, indicating their would be no CD in the system.
