Latest post 06-11-2010 5:27 PM by JonR. 2 replies.
Page 1 of 1 (3 items)
  • 06-11-2010 12:02 PM
    • JonR
    • Not Ranked
    • Joined on 06-11-2010
    • Posts 2
    B&O 4500
    Hi
    Bit of a shot in the dark, but I was wondering if anyone knew if the B&O 4500 master amp has an internal fuse or perhaps a power relay that could have got stuck? It has been working perfectly for two + years, I went away for a two week holiday, turned it off from the wall socket power so the whole system was compeletly off (something I hardly ever do) came back, switched it on, and nothing. Dead, no usual click as it switches into standby, no red lights behind the glass of each of the units. I checked the plug socket fuse and power is going in, which made me think perhaps it could be a stuck relay or perhaps the unit has an internal fuse. Any suggestions would be greatfully received... the mystery is it was working fine, was not touched, and then I simply switched the power to it on the main wall socket and nothing...
    Regards
    Jon
  • 06-11-2010 3:50 PM In reply to
    • Jandyt
    • Top 10 Contributor
    • Joined on 04-01-2007
    • Clitheroe, Lancashire, UK
    • Posts 13,004
    Re: B&O 4500
    Hi Jon.
    I'm not a techie, but I just had a look at the service manual, and there appears to be 4 internal fuses.
    The manual is on site, but you need to upgrade your membership to download it.
    Andy T.
    Poor me, never win owt!
  • 06-11-2010 5:27 PM In reply to
    • JonR
    • Not Ranked
    • Posts 2
    Re: B&O 4500
    Hi Andy
    Many thanks, I'll look into upgrading and getting the service manual - might be the way to go here.
    Jon
