Latest post 05-31-2010 10:29 AM by tournedos. 4 replies.
Page 1 of 1 (5 items)
  • 05-31-2010 5:21 AM
    • Dmitry
    • Not Ranked
    • Joined on 05-17-2010
    • Rostov-on-Don, Russia
    • Posts 36
    Can the CD6500 be controlled via BM5500?
    Hi, everyone!
    Just found the white (unfortunatelly) CD6500 on sale, and curious, if it will be controlled via my Beomaster 5500?
    Is the CD6500 the same CD5500 with additional functions?
    Thanks!
    Beomaster 5500, Beogram CD50, Beogram CD5500, Beogram 5005, Beogram 5500, Beolink 1000, Beo4, Beovox 3702
  • 05-31-2010 5:36 AM In reply to
    Re: Can the CD6500 be controlled via BM5500?
    No difference really, just the outside finish (if it were aluminum), model number and a different CD mechanism. It will work just the same.
    Early (most?) 5500's do not have the tray cutout for CD singles, so if you need to play those, a 6500 will be a better choice.
    -mika
  • 05-31-2010 8:59 AM In reply to
    • h1npw
    • Top 75 Contributor
    • Joined on 04-16-2007
    • A cricket ball throw from Trent Bridge
    • Posts 776
    Of all the CD5500s I've come across (quite a few!), the vast majority have been the later ones which can play the CD singles.
    Cheers
    Nigel
  • 05-31-2010 10:04 AM In reply to
    • Dmitry
    • Not Ranked
    • Posts 36
    It turned out, this CD6500 is WITHOUT the RCA- only DIN!
    On my BM5500 and CD50 I've made the controls via DIN and sound- through RCA, which gives freedom to use any RCA cable to adjust sound to the speakers and room.
    Are all CD6500 lack RCA and I'll better look for CD5500 instead?
    Thanks!
  • 05-31-2010 10:29 AM In reply to
    Well, I'm not going to get into the cable debate... But I'd just use the DIN instead of getting my choices limited because of a connector.
    6500 indeed has no RCA connectors, I forgot about that.
    -mika
