Latest post 06-11-2010 6:26 AM by Koestie. 3 replies.
Page 1 of 1 (4 items)
  • 06-10-2010 11:49 AM
    BeoCenter 9500 and Beolab 3500 Compatibility
    Hello friendly forum denizens,
    I am the proud and happy owner of a Beocenter 9500 and am contemplating adding a BeoLab 3500 to my setup.
    Are the newer Beolab 3500 models backwards compatible?
    As far as I could find out the Beocenter 9500 only supports MCL whereas the BeoLab 3500 supports ML?
    Can I buy any Beolab 3500 or do I need to buy the older LCS 9000 version?
    Many thanks for your help,
    Michael
  • 06-10-2010 12:43 PM In reply to
    Re: BeoCenter 9500 and Beolab 3500 Compatibility
    Much of the info you require is here
    http://www.beoworld.org/faq_view.asp?id=80
    Regards Graham
  • 06-10-2010 1:56 PM In reply to
    • stefan
    • Top 50 Contributor
    • Joined on 04-16-2007
    • 200 miles from Struer
    • Posts 1,733
    Michael,
    welcome to Beoworld. I recommend a Beolink converter 1611 to get your BC9500 Masterlink ready. Maybe you want to add other ML products like Beovision, BL2000, Beolink active.... in future. You just need a 7pin Datalink cable, a 1611 converter and a Masterlink cable to connect the BL3500. Should work with all BL3500s...If you are using a two way remote - Beolink 5000/7000- to control your BC9500, it won`t work with BL3500 unless you set it to one way.
    Stefan
  • 06-11-2010 6:26 AM In reply to
    Many thanks, that is much appreciated!
    Cheers
    Michael
