I have connected my MacBook via a Ethernetcable with the Beomaster. The Apple network administration programm shows me the IP adress which I also can see inside the BeoMasters Network Info, and its says "Connected" (with a yellow status light). But when I want to connect the MacBook via BeoConnect (fresh installed), BeoConnect says "No connection possible, pleas check IP Adress, Computername, Passwort and Network connection.
What the hell is wrong here ?
