Callen:
Hi Malcolm, I spoke to my dealer about this the other day, the biggest feature is the ability to rename the text which appears on screen. i.e. If you press DTV it can be renamed to say 'Sky' or anything you want really. I'm planning on having 'PC' renamed to Xbox etc etc.
Regards,
Cal
Is this something I can do, or has it to be done by a B&O tech guy?
_____________
Happy owner of: BV10, 2 x Beocom 2, Beocom 6000, Beocenter 2, Beolab 3, Beolab 2000, Beo4, Beolab 11
1:st prize winner Beoworld January Price Draw.
