Hi all,
Due to a lack of space I need to pass on a couple of systems................. :-(
First up is this;
BeoCentre 2600 in Teak with BeoVox 1000 speakers also in Teak.
BC recently serviced by a certain Mr T Jarman! so everything is there and works as it should. :-)
The speakers haven't had the covers taken off of them (these where tacked on at the factory) so I'm not sure if there is any issues with the foam, although to my ears they sound fine!
The speaker connections could probably do with redoing to ensure the pin and spade connector is attached in a way you might like.
I'm based about 15 mins from J10 on the M25 near the A3.
I'm looking for £50 for this and if I don't get any joy I'll be sticking it on ebay :-( this weekend.
Any questions or extra pictures etc just ask.
Cheers
GUY
Train Hard - Run Fast - Hit to Kill!!!
