Latest post 04-17-2010 7:24 AM by a11mcr. 4 replies.
Page 1 of 1 (5 items)
  • 04-16-2010 4:29 AM
    • a11mcr
    • Top 500 Contributor
    • Joined on 07-29-2007
    • Redcar,North East
    • Posts 154
    • Silver Member
    Beosound 9000 connection options?
    Hi i am looking to buy my first BS9000 but need to know a few things first?
    in my bedroom i have a BV MX4000 and VX5000
    in my living room (where the 9000 is going) i also want to connect a beocord 4500 and beogram 4500
    What i want is to control all of the above via the beo4 and wanted to know if this is possible and what would i need (i think i have a beolink converter in my shed with my mx4002)
    also which one is better mk1, mk2, mk3?
    cheers
    mark
    Kind Regards, Mark
  • 04-16-2010 5:01 AM In reply to
    • Craig
    • Top 10 Contributor
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    Re: Beosound 9000 connection options?
    Don't think there will be any problem conecting the MX via the Materlink conection. You will however find that there is no Datalink on the AUX connection. Even though it is a 7 pin conection. Only 5 of the pins a re connected. You could connect the Beocord and Beogram to the AUX with some sort of splitter, but you wil not be able to control them with your Beo4.
    CraigSmile
  • 04-16-2010 5:16 AM In reply to
    • Daniel
    • Top 50 Contributor
    • Joined on 04-17-2007
    • Svinarp, Sweden
    • Posts 1,284
    BeoWorld member Ridax maybe has a solution for you:
    http://home.swipnet.se/ridax/beoir.htm
    You can try to mail him: mail@ridax.se
  • 04-16-2010 5:24 AM In reply to
    • Daniel
    • Svinarp, Sweden
    • Posts 1,284
    a11mcr:
    Go for mk3, it's newer.
    If I recall correct, mk2 had an improved CD mech and mk3 has netradio and netmusic. It's possible to upgrade mk1 and 2 to netradio and netmusic.
    There's no external red power button on mk3 (some people think the button ruins the design).
  • 04-17-2010 7:24 AM In reply to
    • a11mcr
    • Redcar,North East
    • Posts 154
    • Silver Member
    Thanks, couldnt i just connect these to the beolink converter (or buy more beolink converters and connect each one?) and then control them via the masterlink connection??
    i have been trying to contact ridax for a few months over another issue with no luck?
    if there is no other way of controling my beocord and beogram via the bs9000 then this may not be the one for meSad
    mark
    Kind Regards, Mark
