Latest post 04-15-2010 12:12 PM by johnheartfield. 3 replies.
Page 1 of 1 (4 items)
  • 04-15-2010 5:10 AM
    BeoComm 6000 pcb
    My MK1 6000 has finally gone into permanent "no signal" and will no longer connect to my BeoCom 2 base unit.
    I fear the solution is a new pcb but am concerned with two things :-
    Can anyone supply a pcb? My dealer says it will cost £75+ for him to do it and it seems an easy task to do myself.
    Will there be any problems with my system after the new pcb is fitted? Other parts are a BeoCom 2, another MK 1 6000 and a BeoTalk 1200.
    John
  • 04-15-2010 5:28 AM In reply to
    Re: BeoComm 6000 pcb
    I think the £75 may refer to the kit to upgrade a Mk1 to Mk2 which (I think) is replacing most of the phones innards, so £75 isn't unreasonable.
    Simon
  • 04-15-2010 6:30 AM In reply to
    You can see HERE what is included in the Mark 1 to Mark 2 upgrade kit
    Regards Keith....
  • 04-15-2010 12:12 PM In reply to
    Thank you for the replies Simon and Keith. Seems more substantial than I thought!!
    I will see if he can negotiate down a little.
    John
