Latest post 04-16-2010 3:50 AM by Kokomo. 10 replies.
Page 1 of 1 (11 items)
  • 04-14-2010 2:24 PM
    • Hampus
    • Not Ranked
    • Joined on 04-14-2010
    • Posts 4
    • Silver Member
    STB-C installation Avant
    I have an Avant 32 VCR without Set top box controller.
    I was at my b&o dealer today and they told me that it is posible to instal that module. I know what i need and it is posible to fix. I just do not know if i can do it by my self.
    1. I am asking for pictures and instalation instructions of the module.
    2. How do i change the software chip for the television? If it is the old software in the television i need to change that module to.
    Best regards
    Hampus
  • 04-14-2010 2:37 PM In reply to
    Re: STB-C installation Avant
    Hampus,
    A Very Warm welcome to Beoworld..
    The STB-C unit is a small box with the circuit board inside as shown below..
    It is fixed on the reverse side of the rear PCB.
    Regards Keith....
  • 04-14-2010 5:55 PM In reply to
    • Hampus
    • Not Ranked
    • Posts 4
    • Silver Member
    Thanks for your quick respons.
    I think som one needs to point it out for me.
    I can open it up tomorow again and take photo of the inside, if not som one her maybe have a picture of the insite of a Avant.
    Regards
    Hampus
  • 04-15-2010 6:14 AM In reply to
    I have a STB-C module available if there is not one currently fitted.
    Neil
  • 04-15-2010 6:17 AM In reply to
    • Kokomo
    • Top 100 Contributor
    • Joined on 08-21-2007
    • Spain
    • Posts 618
    Keith Saunders:
    Hampus,
    On the subject of the STB-C, I had mine installed in my Beovision 3 by a dealer. If at some time in the future I want to update it, does the chip plug in or is some soldering required? Is it a DIY job?
  • 04-15-2010 6:27 AM In reply to
    Kokomo:
    As shown in the picture, this is a plug in chip..
    Provided you use the normal "Static" protection with wriststrap and grounded mat, then it can be done quite quickly. No soldering is required.
    Regards Keith....
  • 04-15-2010 10:06 AM In reply to
    • Kokomo
    • Spain
    • Posts 618
    Thanks Keith, much obliged.
    Now for my next questions! My current STB-C controls my Sky+ box. Do newer chips permit control of the new Freesat boxes (Humax for example).
    If so, how much is the chip?
    Thanks.
  • 04-15-2010 10:30 AM In reply to
    The chipsets are split into 4 regions of Europe and the chipset for western Europe is shown below
    West Europe 4.11
    1. HUMAX Cl-51 OOC
    2. Humax IRHD-5000C
    3. Humax IR-FOX C
    4. Humax IPVR 9200C
    5. HUMAX PVR 9200T
    6. HUMAX HDCI-2000
    7. Philips DCR 1211/18
    8. Philips DSR7005
    9. Philips DCR 7101/03
    10. Philips DSR7121/22
    11. TF4000PVR
    12. T.FIELD 771 OHDPVR
    13. TF5800PVR
    14. TF581 OPVRt
    15. TF5000PVR
    16. MOTORO. DVi5000
    17. DREAMBOX DM7000
    18. SA Exp 8455DVB
    19. Virgin V+
    20. BT Vision
    21. HUMAX FOX SAT HDR
    22. Technomate TM5000
    23. PACE SKY+
    24. SKY DIGITAL
    25. Apple Remote
    26. ASTON XENA 1600
    27. KreatelIP-STB 1760
    28. SAMSUNG DCB9401
    29. SAMS. DCB-H360R
    30. Samsung DCB-B270R
    31. Samsung DCB-P850RS
    32. SAMSUNG SMT1xOO
    33. Sony Playstation 3
    34. CANALdigital B+
    35. CANALdigital NL
    36. indi 5800C RAW
    37. STARHUB
    38. TELENET DBAD101
    39. Belgacom TV
    40. TViX M6500A HD
    41. Thomson DCI52NUM
    42. Thomson DCI62UPC
    43. Thomson SkyHD
    44. REBOX RE-1150CO
    45. REBOX RE-1250CO
    Regards Keith....
  • 04-15-2010 11:45 AM In reply to
    The price seems to largely depend on the relationship you have with your dealer.  Last time I purchased one, I paid £15 ... but I have heard of people paying £45 and upwards ...
    Neil
  • 04-15-2010 2:06 PM In reply to
    Also if you don't have a decent chip removal tool (not just a PC memory one!) you can easily break the side of the chip socket that will then render the board unusable...........
    Don't ask me how I found this out with a 32" Avant motherboard............ :-(
    Train Hard - Run Fast - Hit to Kill!!!
  • 04-16-2010 3:50 AM In reply to
    • Kokomo
    • Spain
    • Posts 618
    Thanks to Keith and others for the responses. Appreciated.
    Smile
