i have recently been given a mx7000 and i am having trouble with the sound, it is distorted, terrible background noise etc, when i run it through a freeview box the sound is fine. i would appreciate any help
Possibly the NICAM decoder. Can you try switching it to mono and see if it goes away?
Neil
thanks neil, that was the problem, you are a star
andrew
These can be reapired if you want the NICAM function.
any idea how much it would cost? is it an easy repair? thanks
Shouldnt cost you more than about £30.
