Latest post 04-07-2010 4:10 PM by kumse. 0 replies.
Page 1 of 1 (1 items)
  • 04-07-2010 4:10 PM
    • kumse
    • Not Ranked
    • Joined on 11-09-2008
    • Posts 21
    Beosound Overture, No response on Tape/CD/IR...
    Hello out there
    I just recived my new Beosound Overture Type 2623, but it does not work as it should.
    At the first look the CD try to focus, but does not spin up. The Tape deck try to load the tape, but does not run the tape. Furthermore it does not react to my Beo4 or Beolink1000.
    Have you seen failure like this before. At my first point i suspect the powersupply to miss a regulated output?
    The radio/lights/sliding doors etc. works perfectly, and sounds nice.
    I have just got a service manual for it, as a starting point.
    Any tips?Smile
    Regards Thomas
