Latest post 04-08-2010 2:51 PM by hebo. 1 replies.
Page 1 of 1 (2 items)
  • 04-08-2010 1:36 PM
    • js
    • Top 500 Contributor
    • Joined on 09-07-2007
    • Brussels
    • Posts 208
    • Silver Member
    BL4000 dimensions
    I think the BL4000 is advertised as being 32cm high. As I wonder whether a BL4000 could be placed in a 32cm high bookshelf, could one of you be so kind and measure one of his own BL4000 and let me know whether it is exactly 32cm high or just a few millimeters shorter than that. Many thanks, js
  • 04-08-2010 2:51 PM In reply to
    • hebo
    • Top 200 Contributor
    • Joined on 04-16-2007
    • Sweden
    • Posts 305
    Re: BL4000 dimensions
    mine is 32,2 cm high, sorry
    It is easy to scratch the alu-surface if you try to push them in.
     BV10
