Depends on the position of each capacitor. Power supply/preamp/amp/signal path/decoupling/crossover etc.
The service manual will give you the part numbers.
Eventual tech info notes and/or aftermarket updates may provide additional info.
A good start is to see what's mounted from the factory.
The service manual is available for download from our main website at a small
membership fee (well worth it).
