Latest post 06-30-2007 12:27 PM by Peter. 3 replies.
Page 1 of 1 (4 items)
  • 06-30-2007 8:47 AM
    • Goldfrog88
    • Top 500 Contributor
    • Joined on 06-07-2007
    • Melbourne, Australia
    • Posts 83
    • Gold Member
    Erm [8-)] DVD2 delayed?
    Is there any more news on the DVD2? I heard today (in Australia) that the product had been set back a month. I wonder what has happened. Also waiting seriously for the technical specifications.
    Filed under:
  • 06-30-2007 10:21 AM In reply to
    Re: DVD2 delayed?
    Is the DVD2 of any use in Australia with only analogue tuner?
  • 06-30-2007 11:36 AM In reply to
    • Doc
    • Top 150 Contributor
    • Joined on 04-17-2007
    • Posts 585
    Re: DVD2 delayed?
    Stupid question of me: what diasadvantage does the analogue tuner has (besides maybe picturequality) compaired with digital (like in a HDR2)?
  • 06-30-2007 12:27 PM In reply to
    Re: DVD2 delayed?
    The HDR2 doesn't have a digital tuner either - but it can use the one attached to the TV. The DVD2 can also actually use the one attached to the TV but not via timer record. Interestingly the model on which it is based does have a link to do this which is present on the DVD2  - I wonder if it has been disabled? At present I would say analogue is about the same as digital in SD form as the signal is stronger. However analogue will be turned off at some stage!
