hi everybody,simple question really is a beomaster 3000-2 amp/tuner compatible with form2 and a8 headphones
Yes, but you will need an adapter as the Beomaster has the larger (6.3 mm) headphone socket. Those should be readily available in any store that sells AV cables and that kind of stuff. I think Form 2 actually came with that adapter.
-mika
many thanks mika and thanks for the quick reply
tournedos: I think Form 2 actually came with that adapter.
Yes Mika, they did come with one as you said.
Craig
Just make sure you buy a stereo, not mono adapter!
