Latest post 03-29-2010 11:11 AM by stefan. 3 replies.
Page 1 of 1 (4 items)
  • 03-24-2010 6:15 AM
    • petermc
    • Top 500 Contributor
    • Joined on 04-16-2007
    • Shepparton, Australia
    • Posts 87
    BeoSound 5 connection cables
    What cables are used to connect the BS5 & BM5 together? Are they proprietary B&O cables and if so, what lengths do they come in?
    Peter
  • 03-27-2010 5:11 AM In reply to
    • Alain
    • Not Ranked
    • Joined on 10-22-2009
    • Bierbeek, Belgium
    • Posts 9
    Re: BeoSound 5 connection cables
    There are 3 cables: one powerlink (looks like proprietary), one video (one connector is some form of DVI) and one USB (standard).
    Length of cables that I received was around 5 meters.  You can probably get longer if needed, just let them know how far you intend to install BS5 and BM5 from each other.
    If you want to mount the BS5 on the wall, with cables hidden in the wall, you will need a fairly thick tube in your wall.  Internal diameter of the tube is 20mm.  You need that width to be able to pull the connectors of the three cables through it.
  • 03-28-2010 3:35 AM In reply to
    • petermc
    • Posts 87
    Thanks for your response Alain.
    Five metres is not that long when mounting the BS5 on the wall. No doubt the longer cables won't be cheap.
    The dealer did mention that B&O have/were coming up with an adapter to link the cables together to make them longer.
    I'll have to chase up the dealer.
    Peter
  • 03-29-2010 11:11 AM In reply to
    • stefan
    • Top 50 Contributor
    • 200 miles from Struer
    • Posts 1,733
    There are three cables. The first is a DVI cable with a mini DVI plug, second is an USB cable with a mini USB plug, third is a four wire power and IR cable. Standard lengths are 4.5 m or 9 m, which includes an USB repeater. 11 m will also work.
    Stefan
