I bought a pair of CX100's for center channel off an AV7000. The options are to place one on it's side over the TV or to hang both from the wall (directly touching)...so it looks like 1 speaker and hang them in the normal vertical position. After reading here about mutiple speakers on 1 channel, i'm confident that the amp in the AV7000 would drive both speakers.
The reason i ask is that the better, high end, center speakers by the likes of Klipsch have 2 X 6 1/2 woofers plus tweeters. I'm thinking that the small 4 inch speakers of the CX100's may need help by driving both for a center channel.
For reference, the fronts are Pentas and the rears 8000's...
Any feedback is appreciated.
Thanks for having the forum.
