Latest post 03-15-2010 1:09 PM by Medogsfat. 15 replies.
Page 1 of 1 (16 items)
  • 01-26-2010 3:07 PM
    • chartz
    • Top 75 Contributor
    • Joined on 07-20-2009
    • Burgundy
    • Posts 984
    • Gold Member
    Beogram CDX display fault
    Hello!
    It's me again!Embarrassed
    I've bought a nice CDX CD player but the display is faulty.
    Any ideas?
    Thanks,
    Jacques
    Jacques
  • 01-27-2010 3:15 AM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: Beogram CDX display fault
    Well, it could be the display iteself but check solder joints on the board, especially at the connectors
    and the display. Check the joints for the track number LED's too, they are often cracked.
    Note where all plugs and cables go, at least one of them can go in the wrong place (!) and destroy one of the processors.
  • 01-27-2010 10:29 AM In reply to
    • Medogsfat
    • Joined on 02-21-2007
    • Posts 4,045
    If that fails I have a spare board with the display attached....
    Chris.
  • 01-27-2010 12:02 PM In reply to
    • chartz
    • Burgundy
    • Posts 984
    • Gold Member
    Thanks Chris.
    I'll try what Martin suggests, then I'll come to you if it doesn't work.
    Jacques
  • 02-02-2010 11:49 AM In reply to
    • chartz
    • Burgundy
    • Posts 984
    • Gold Member
    I haven't fixed that yet.
    I've got a spare CD 3300 with a good display. Would it fit?
    What could go wrong in this display? I've checked all the solders. Anyway one only wrong segment is weird.
    Jacques
  • 02-02-2010 12:32 PM In reply to
    • Dillen
    • Posts 5,008
    Well, basically LEDs (diodes) are merely semiconductors and semiconductors are known to
    fail occasionally. I suppose that's what has happened here.
  • 02-02-2010 12:40 PM In reply to
    • chartz
    • Burgundy
    • Posts 984
    • Gold Member
    I've found this, and that—it's still available!
    I know it's not useful really, but a minter with a defective display is not satisfactory. Super Angry
    By the way, I got it for about 50 € (original box, but no transit screws). I had to re-solder three green leds and a few griplets (whatever that means) too!
    Jacques
  • 02-02-2010 12:48 PM In reply to
    • Dillen
    • Posts 5,008
    I think, I would grab Chris' spare board and mount either the whole board or just the display.
  • 02-02-2010 2:05 PM In reply to
    • Medogsfat
    • Posts 4,045
    I'm not sure of the working condition of the board components as it came from a totally wrecked CDX which I bought for parts so never fully tested it as far as the touch sensors etc.... The display was working fine though as I remember getting the CDX in question to start (with a lot of encouragement) and remember it whizzing through the tracks backwards & forwards & lighting up like a Christmas tree.
    It's still yours if you want it.
    Chris.
  • 02-03-2010 1:24 AM In reply to
    • chartz
    • Burgundy
    • Posts 984
    • Gold Member
    I do!
    You have a PM.
    Cheers,
    Jacques
    Jacques
  • 02-26-2010 4:48 AM In reply to
    • chartz
    • Burgundy
    • Posts 984
    • Gold Member
    Hello!
    Thanks to Chris I finally had my display working completely!
    I changed the whole board. It had quite a few bad solder joints as expected of course. It didn't work first time, silly me, I had missed a few more bad solders (no stop, no repeat—I had focussed on the leds). My original PCB presented the same symptoms, even if it was one of the last produced.
    Thanks again for your support and invaluable advice.
    Jacques
    Jacques
  • 03-14-2010 10:40 AM In reply to
    • chartz
    • Burgundy
    • Posts 984
    • Gold Member
    The picture!
    Jacques
  • 03-14-2010 2:57 PM In reply to
    Wel done and a big thanks to Chris who seems to have an inexhaustible supply of parts and generosity! I do like the CDX. I know it uses the TDA1540 DAC which should be antiquated, but it really does sound very good!
  • 03-14-2010 3:31 PM In reply to
    Result :)
  • 03-15-2010 4:25 AM In reply to
    • chartz
    • Burgundy
    • Posts 984
    • Gold Member
    Peter :
    ...big thanks to Chris who seems to have an inexhaustible supply of parts and generosity! I do like the CDX. I know it uses the TDA1540 DAC which should be antiquated, but it really does sound very good!
    Yes Chris is a nice fellow!
    Yes the CDX is a nice player. I've had many, including TDA 1541-based ones, Bitstream ones, and now I know what I prefer. Amazing, isn't it?
    Jacques
  • 03-15-2010 1:09 PM In reply to
    • Medogsfat
    • Posts 4,045
    Peter :
    Embarrassed
    Aw - shucks guys, it's a labour of love honest....
    Beautiful players & I NEVER throw parts away from vintage stuff, much to my wifes chagrin.
    Chris.
