Latest post 03-13-2010 6:10 PM by pcd2005. 2 replies.
Page 1 of 1 (3 items)
  • 03-11-2010 4:29 PM
    • pcd2005
    • Not Ranked
    • Joined on 03-04-2010
    • Gloucestershire UK
    • Posts 14
    • Silver Member
    Beolab 1700, Beocord 1100 ...control 'buttons'
    I have recently acquired a Beolab 1700 (cheaply!) which has one of its black 'buttons' missing.  These are the metal bits that pass through the front slot and locate into the switches - size approximately 25 x 30 x 3 mm.  It should be plain black ie no red lines.  Does anyone have one of decent appearance in their spares box that they would be willing to sell?  I am pretty sure these bits were used on other applications too.  Many thanks.  Peter
  • 03-11-2010 5:09 PM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: Beolab 1700, Beocord 1100 ...control 'buttons'
    I'm sure, I can find one.
    Did you get my message regarding the Beomaster 1700 tuner ?
  • 03-13-2010 6:10 PM In reply to
    • pcd2005
    • Not Ranked
    • Posts 14
    • Silver Member
    I should be Big Smile if you do find one - and yes I sent you a direct email about the 1700 tuner... Many thanks,
    Peter
