Hi All!
I bought a B&O RX2 used, and have been using it for about 6-7 months & loving it! However, The belt was stretched out, a little shot <slght variance in speeds etc.>So I bought a replacement belt for it & changed it..Seemed pretty straightforward to do<so I thought>...I simply removed the platter, then took the two Phillips screws out of the bottom to get the top part of the plinth loose, actually I just opened it about a 1/2 inch enough to get the belt out, to get to the motor pulley & I replaced in the same path it was before without disturbing anything <wires etc> & put it all back together. Now...It doesn't seem to power up anymore? I must have disturbed something inside, but I do not know exactly what...Any ideas? I checked the usual stuff...I found no broken or loose wires, & I checked the power supply fuse ect. no deal, fuse is FINE...
Is there a "interlock switch"in there or something else I don't know about? It's not making any noise at all now, and platter won't spin, motor is not even making a sound...The A/C outlet is OK, as I have a TX2 also, & it works perfectly!
Any help is greatly appreciated!!!!THANKS IN ADVANCE!
I am using the TX2 until I solve this issue, but I miss my RX2!
-MT
