Latest post 03-07-2010 5:04 PM by Peter. 1 replies.
Page 1 of 1 (2 items)
  • 03-07-2010 4:02 PM
    Beogram 4000 - did it use same wooden frames
    Does anyone know if the Beogram 4000 shares the same wooden surround frame with other Beogram turntables? I am looking to replace my surround and am looking at multiple source possibilities.
    Thanks Smile
  • 03-07-2010 5:04 PM In reply to
    Re: Beogram 4000 - did it use same wooden frames
    They have different part numbers but they are the same size.  You may need to swap brackets but definitely possible.
