Latest post 03-06-2010 11:48 AM by Medogsfat. 2 replies.
Page 1 of 1 (3 items)
  • 03-06-2010 8:40 AM
    Beomaster 5000 and RL60
    Hello!
    I'm new to this forum and B&O products in general, i recently bought beomaster 5000 and RL60 together on ebay for a cheap price. But when buying it, no cables/connections or manual came with it. Now i got all cable and connections for aux and turntable, but i can't get the beomaster to work, whenever i plug it in there's a tiny dot on the screen, and when i press "store" it starts blinking "P". I have been searching a lot on the internet on how to make it work, also a lot on this site, but i cant find any solutions. help!
    Jostein
  • 03-06-2010 11:44 AM In reply to
    Re: Beomaster 5000 and RL60
    welcome and congratulations on your purchase
    the "P" is for radio Program ... that is, the [STORE] is taking the current tuning frequency (MW, LW, or FM) and wanting to now assign a number to it so you can recall it
    Do you have one of the two controls that supports the Beomaster ?
    Either the Terminal 5000 or the Master Control Panel 5000 ?
    I strongly recommend you take up a Gold membership to Beoworld ... you will be automatically registered in the monthly raffle ... and you will also have access to scanned copies of the manuals in the Product section of the Beoworld site
    First B&O (1976) was a Beogram 1500 ... latest (2011) change has been to couple the BL11 with the BL6Ks *sounds superb*
  • 03-06-2010 11:48 AM In reply to
    • Medogsfat
    • Top 10 Contributor
    • Joined on 02-21-2007
    • Posts 4,045
    You can select whichever input/function required using the manual buttons behind the drop down front panel. For any radio reception at all you MUST connect something to the ariel socket at the back, even a piece of wire should do for testing purposes.
    Chris.
