Latest post 03-23-2010 4:34 AM by joeyboygolf. 1 replies.
Page 1 of 1 (2 items)
  • 03-22-2010 4:09 PM
    • Jim
    • Not Ranked
    • Joined on 03-09-2010
    • WA State
    • Posts 7
    Beogram 4004 Arm Adjustment Instructions
    I have a newly purchased 4004 and the arm with the cartridge rested against the optical arm . I have adjusted the 2 screws in the back to get it so it does not touch. But, they still are not parallel. The arm does go down and up as it should but needs proper adjustment. Does anyone have the proper instructions for aligning he arm? Any help would be appreciated.
    Jim
    Filed under:
  • 03-23-2010 4:34 AM In reply to
    Re: Beogram 4004 Arm Adjustment Instructions
    You can download the service manual from this site by becoming a silver (£15) or gold (£30) member.
    Gold membership also gives 12 free entries in the monthly draw and also helps to finance the site.
    Regards Graham
