Hasn't 16C1 or one of the other caps just shorted or gone open circuit ?
It's quite common to see the caps on the power supply board (module 16) go bad,
often blowing the fuse for the low voltage transformer too.
I suggest you replace the lot. Note that 16C1 has two of its three negative pins used !
16IC1 doesn't have to be a TEO1089, it can be f.e. a BDX34A (with a slightly
different casing).
But are you sure that 16IC1 is bad ?
