Hello
I need some help on setting up a Beosystem 3
The problem I am having is with the sound setup
The configuration is a Beosystem 3 connected to a Samsung TV
Centre Speakers is a pair of 4000’s Fronts 8000’s Rear 6000 and a Beolab 2 Subwoofer
The problem I have is I can’t configure the speakers
SPEAKER TYPE: When I go to Speaker Type I can hear the sound from each speaker and it will let me store
TV SPEAKER ROLES: When I go to TV Speaker Roles I can hear the sound from each speaker and it will let me select but I can’t store?
SPEAKER DISTANCE: Grayed Out I can’t access
CALIBRATE THE SOUND LEVEL: Grayed Out I can’t access
SOUND AJUSTMENT: I can see and access Volume, Bass, Treble, Subwoffer, Loudness But I can’t see Default Video or Default Audio
SOUND SYSTEM: I can access but can’t make any changes
I know all the speakers are working as I can hear the sound from them when I try to set the Speaker Type or Speaker Roles
So currently it does not matter what I try to select I am only getting sound out of the Center 4000 speakers and the Subwoofer
I can’t register any other speakers
Can anyone out there point me in the right direction?
Barry
