Latest post 02-20-2010 9:53 PM by jam57. 2 replies.
Page 1 of 1 (3 items)
  • 02-20-2010 6:09 PM
    Volume Control Failure and other replacement parts
    I just got a beomaster 1900 and 2 Beovox S45-2 speakers for the great price of $0. A Gentleman I work with knew that I was into music and audio gear and decided that I needed this more that he. Anyway, it has a few issues. The Bass slider is non functioning, but i think I've found the answer to that on another post. I also need to replace several of the indicator lights on the front panel. Where can I get the right bulbs for that?
    The big issue though is that the sensi-touch volume controls have stopped working. To change the volume, i have to use the preset volume switch and power down then back up to affect a change. Is this a common thing, and what kind of suggestions might you folks have as to what may be going on with that.
    Also, I'd like to find a set of the "plug-in" rabbit ear style antennas and a full schematic for this as well.
    Any help would be greatly appreciated...this will be a nice addition and conversation piece in my office once its up and running as it should
  • 02-20-2010 9:47 PM In reply to
    • jam57
    • Not Ranked
    • Joined on 02-02-2010
    • Denver CO
    • Posts 27
    • Gold Member
    Re: Volume Control Failure and other replacement parts
    Congratulations and welcome to Beoworld
    I believe a set of lights are available from Martin ( user name dillen ). He may be able to help with the volume controls also. When using the preset volume, changes take effect after turning the power button off and then turning back on. Was the remote controller included with this set and if so does it change the volume?
    John
  • 02-20-2010 9:53 PM In reply to
    • jam57
    • Not Ranked
    • Denver CO
    • Posts 27
    • Gold Member
    Sorry but I forgot that remote control was not available on the BM1900
    John
