Latest post 06-27-2007 2:48 PM by Craig. 5 replies.
Page 1 of 1 (6 items)
  • 06-26-2007 4:09 PM
    BeoSound 3000
    How do i take the glass windows off the front to clean them?
    Filed under:
  • 06-26-2007 4:38 PM In reply to
    • Alex
    • Top 25 Contributor
    • Joined on 04-16-2007
    • Bath & Cardiff, UK
    • Posts 2,990
    Re: BeoSound 3000
    Open the doors (same way you usually do), and simply pull off from the outside inwards. They feel like they've snapped off, but they haven't! When you're finished, clip the doors on from the top clips first and then into the bottom clips.
    Be careful not to let them try and close while you're popping them out or pushing them back in! Make sure the doors are open when you push them back in, otherwise they'll slide out half way through you clipping them back in.
     Weekly top artists:
  • 06-26-2007 9:04 PM In reply to
    • petermc
    • Top 500 Contributor
    • Shepparton, Australia
    • Posts 87
    Re: BeoSound 3000
    Agree with above but it's easier to open the doors normally and then turn the power off at the switch. That way the doors won't try and close while you're trying to remove/reinstal the glass.
    Peter
  • 06-27-2007 6:10 AM In reply to
    • Alex
    • Posts 2,990
    Re: BeoSound 3000
    Although if you leave it unplugged for too long, the unit will enter PIN Protection mode...
     Weekly top artists:
  • 06-27-2007 6:38 AM In reply to
    Re: BeoSound 3000
    Alex:
    Depending on the age of it, it may not be PIN code protected.
  • 06-27-2007 2:48 PM In reply to
    • Craig
    • Top 10 Contributor
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    Re: BeoSound 3000
    When did they put PIN Code protection on the BS3000? Mine is a Large Clamper model, but has no PIN.
    CraigBig Smile
