Latest post 02-17-2010 2:38 PM by tournedos. 9 replies.
Page 1 of 1 (10 items)
  • 02-17-2010 12:42 PM
    Beolink 1000 problem
    I am new in this forum. I have a question for you : My Beolink 1000 has a peculiar problem. Sometimes the volume buttons don't work. Then I press the CD or Radio or Phono button which work normally and then I press the volume button again ant it works ok. Does anybody have an answer? Thanks
  • 02-17-2010 12:54 PM In reply to
    • Stonk
    • Top 50 Contributor
    • Joined on 04-16-2007
    • Marlow, Bucks, UK
    • Posts 1,688
    Re: Beolink 1000 problem
    Hi there, welcome to Beoworld.
    It sounds like a membrane problem. Take it apart and see if the dots in the membrane have worn away. Have a look at THIS thread for possible remedies.
    Steve
    If you think nobody cares, try missing a couple of payments.
  • 02-17-2010 1:00 PM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Your TV and radio will only react to video/audio commands respectively.
    So if you changed channels on your TV, switch it off and then want to adjust the volume on
    the radio, you will have to first put the Beolink 1000 into audio mode by pressing Radio.
  • 02-17-2010 1:28 PM In reply to
    • Medogsfat
    • Joined on 02-21-2007
    • Posts 4,045
    Stonk:
    Steve
    I have since found yet another remedy for fixing the MK 1's & 2's.
    Take a non working acetate laminated membrane from a MK3 or later version. Split the laminated sheet & the top layer has the electrolytic dots intact which will fit directly into an earlier version. The dots are smaller than on the original sheet & square but it does work. You can actually get 2 replacement sheets from one non working laminated one by doing this. I have some spare if the OP needs one.
    Chris.
  • 02-17-2010 1:48 PM In reply to
    I have put a round piece of aluminium foil on those dots because they were worn but the problem is still there. I don't think is due to that because there are other dots with intact conductive paint ( for ex the buttons for mute) with the same problem. The funny thing is that after pressing  the working buttons( for ex CD, Radio, Phono, Tape etc) the volume buttons work again normally
    thanks for you help
  • 02-17-2010 1:53 PM In reply to
    Then my money is on the theory that the remote somehow switches to video mode by itself... perhaps one of the video source buttons (TV/SAT/V.TAPE) is somehow sticking?
    Do you have any B&O video equipment? If not, the next time the remote acts up, try the digicam trick. Aim the transmitter end to a digital camera / camera phone and look at the preview while pressing one of the volume buttons. If you see the remote transmitting (the LEDs show up pale blue on the preview) but your stereo doesn't react, the remote must be in video mode.
    -mika
  • 02-17-2010 2:11 PM In reply to
    I have no tv connected, I own a Beosystem 4500 + Beolab 4500.
    Tournedos you were absolutely  right! The remote works ok ( I am impressed by the trick using the digital camera, it is really a good party trick to impress friends) , for some reason the remote switches to video. I only have to press again CD or Radio ot whatever I am listening in that moment .
    Thanks to everybody
  • 02-17-2010 2:18 PM In reply to
    Gee, I feel like a regular Sherlock now! Laughing
    Looking at the remote, all the video source buttons (TEXT also works as one) seem to be on the same column. I guess there could be some surface leakage on the PCB due to dirt or corrosion that will eventually cause the remote to register a click there, or perhaps one of the membrane switches is a bit "lazy" getting back up. You might try cleaning the PCB with a cloth dampened in isopropanol, it might help.
    -mika
  • 02-17-2010 2:29 PM In reply to
    what's PCB?
  • 02-17-2010 2:38 PM In reply to
    Printed Circuit Board, the plate where all the components sit on and where the membrane makes contact. Don't overdo the alcohol - just a damp cloth, no soaking.
    -mika
