hello
i need some help
i have had a mx4002 for some 11 years , and had it set up with my beovison 7 vx 7000 and a set top box and a 9000 be0-sound
it sadley died the other day , and as a stop gap  have bought a 2nd hand one a bit newer than the orginal one , it works ok , i need help in geti ng the vxux/vtape/dvd/ and sat functions to work on it , the master link audio is all ok
i can tne the tv in to the rf feed from down stairs on 799 and then control the item from the mx4002 , but a ssoon as i change function or turn it off it has no memeory of the function and if vtape etc is pressed only grey haze is visible
i would welcome amy suggestions on how to do this
