Latest post 01-27-2010 2:41 PM by macjonny1. 2 replies.
Page 1 of 1 (3 items)
  • 01-27-2010 11:51 AM
    Beovision 7 - Projector out and 3D
    If I buy a projector with 3D, and connect it through DVI, will it be possible to watch 3D movies with the cinemafunction on a beovision 7-40 mark3?
  • 01-27-2010 12:18 PM In reply to
    Re: Beovision 7 - Projector out and 3D
    Hi
    As far as i know, every input in your tv can be broadcastet through DVI out( please correct me if this is not the case). So if you connect a 3D player to your tv, and the projector can show 3D, i cant see why this should not be possible. However, maybe there is an issue with DVI not being able to carry the data needed to broadcast 3D.
    /Ehlerz
    BV7-40 MK IV, BL5´s, BL3´s, BL 3500, BL7-4, BS3000, BC 6-23, BV 1, BS3.
  • 01-27-2010 2:41 PM In reply to
    I doubt it....the signals for 3D go through the HDMI 1.4 spec and I don't see how that would travel over your DVI.
