Latest post 01-26-2010 5:51 PM by ohjay. 4 replies.
Page 1 of 1 (5 items)
  • 01-26-2010 5:24 PM
    • ohjay
    • Not Ranked
    • Joined on 01-26-2010
    • Posts 3
    Beomaster 2400
    The Balance knob (slider thingy) isn't working, can't get the sound to come out of both speakers. Should I crack open the machine to see if I can fix myself, or is that not a good idea?
    Any ideas, tips, am I in the right spot?
    Ok thanks for your time.
  • 01-26-2010 5:27 PM In reply to
    Re: Beomaster 2400
    Depends how technical you are! The 2400 is not the simplest device to disassemble, or more accurately, re-assemble!! I would guess that one side of the power amp needs attention - capacitors a common culprit but clearly all sorts of issues - clearly needs servicing.
  • 01-26-2010 5:33 PM In reply to
    • ohjay
    • Not Ranked
    • Posts 3
    Re: Beomaster 2400
    Thanks for the timely response. I have someone with me who's great at fixing things so we might give it a try.
    I don't really have the means to send it to Denmark you know :)
  • 01-26-2010 5:48 PM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: Beomaster 2400
    I agree with Peter though it could easily be a defect in the balance slider.
    The sliders are no longer available but usually repairable.
  • 01-26-2010 5:51 PM In reply to
    • ohjay
    • Not Ranked
    • Posts 3
    Re: Beomaster 2400
    Thank you Martin
