Latest post 01-24-2010 5:25 PM by beoaus. 4 replies.
Page 1 of 1 (5 items)
  • 12-15-2009 9:16 PM
    • beoaus
    • Top 150 Contributor
    • Joined on 04-16-2007
    • Melbourne, Australia
    • Posts 445
    BV 7-40 with DVI port - Switching Project
    Hello,
    This is my graphic, sorry about the TV.  I am wondering if this would actually work? There are a few switches here so I'm not sure if they degrade signal or I'll end up with a picture with voice some mill-seconds behind or I induce other problems, or I am I just mad...
    Looking at the Gefen products...
    beoaus.
  • 12-16-2009 8:15 AM In reply to
    • stefan
    • Top 50 Contributor
    • 200 miles from Struer
    • Posts 1,733
    Re: BV 7-40 with DVI port - Switching Project
    Should work. But maybe it would be easier with a Gefen 4x2 switcher/splitter. It`s for 4 HDMI sources and 2 displays (outputs).
    http://www.gefen.com/kvm/dproduct.jsp?prod_id=8177
    Connect the first to DVI input of your BV7-40. The second can be connected to a HDMI - composite downscaler CM-388
    http://www.lektropacks.co.uk/view_product_standard.php?product=1001184&show=55&sub1=55
    Connect the analogue video- and audio outputs to the same port of your BV7.
    The Gefen switcher can be controlled via PUC. That`s all. Less devices, less cabling.
    I had a similiar setup with a Gefen TV splitter, a Gefen HDMI - composite scaler and a Philips Surround headphone amp to convert the digital audio from my TVIX 6500 box to analogue stereo for linkrooms. It worked, everything in sync.
    Stefan
    Yes, we are mad.......
  • 12-16-2009 5:22 PM In reply to
    • beoaus
    • Posts 445
    I looked at the box but its expensive and at this stage I think I don't need it...
    I have all the systems listed already accessible in link rooms, via the scart... Those connections I omitted to make the diagrams easier.  I have not bough the TiVo but probably will.
    beoaus.
  • 01-13-2010 4:38 PM In reply to
    • beoaus
    • Posts 445
    Came up against a problem. I have not bought the products yet...
    Tried a test with and Apple TV and Panasonic DMR-BW500. I set both to handle DVI-I in HDTV menu.  When I do this and manually change the cables no matter what I do only one delivers the HD picture through the DVI port. I swapped cables but still have the same problem. I would have thought a quick cable change and flicking between V.AUX and Camera should have worked?
    I can't bear to loose a PUC to control the splitter (I only have 2) so I was planning to do this manually via the Gefen remote....
    Have I struck a issue or is my test invalid?...
    beoaus.
  • 01-24-2010 5:25 PM In reply to
    • beoaus
    • Posts 445
    Can anyone help here?
    Thanks, beoaus.
