Hello
This morning I start to play on a Beocenter 7002, all pcb are recapped including the radio section. I have a problem on this pcb (PC2 - the one under the turntable), the signal is good, the receptions are good, not disturbed and frequencies are discriminated perfectly.
BUT... the sound is loud, one channel is better but each if compared with another PCB installed in THE SAME beocenter is not good; using the better PCB the sound is powerful, warm and detailed on the high frequencies and both channels have the same output level.
So I'm here to ask you a suggestion, I have the service manual, the frequencies emitter (88 - 108MHz) and a good oscilloscope (and 2 probe too... WOW! :) ); the problem described could be solved with FM readjustment as described in the service manual?
I need an encouragement
this is my first time.....
ciao ciao
Eugenio
This is my creature from the dust
Watch Beocenter 7002 - Tonearm rewired - First check in Educational & How-To | View More Free Videos Online at Veoh.com
