Latest post 01-22-2010 6:22 PM by elephant. 1 replies.
Page 1 of 1 (2 items)
  • 01-22-2010 6:16 PM
    New BM Link for MAC/BEOPORT
    Hi All
    I recently completed a survey for B&O and while doing so gave some feedback in relation to beoport and MAC. More specifically how BMLINK no longer worked properly since itunes version 8.1.
    I received the following reply:
    However, it is correct that BeoPort was not made to support MAC
    > OS. A Swedish MAC programmer was so kind to develop BM-Link. We have
    > been in contact with the programmer regarding this issue and we have
    > sent hardware to him, so he maybe can get BeoPort compatible with
    > MAC OS X Snow Leopard. However, we have to say that there is no
    > solution at present.
    A week later I then received the following reply:
    We can inform you that on http://www.odlund.se/bmlink/download.html you are able to download version 1.5.3 which supports iTunes 9 and MAC OS Snow Leopard.
    Is this then a new piece of software developed by Anders? Anyone used this version ?
    I know Philippe Robin has been busily working away on a solution which ive been trialing but i need to upgrade to itunes 9 to get it to work properly.
    Regards
    David Coyne
    BV8-40, BC6-26, BC2, Beolab 9's, Beogram 7000, Beogram 9500, Beoport, Beotalk 1200, Beocom 6000, Beolit 1000, 800, 700, 600, 400
  • 01-22-2010 6:22 PM In reply to
    Re: New BM Link for MAC/BEOPORT
    Hi David,
    there are already a few threads on this, including some tests I have done here
    Ed~2
    First B&O (1976) was a Beogram 1500 ... latest (2011) change has been to couple the BL11 with the BL6Ks *sounds superb*
