Latest post 03-28-2010 1:29 PM by yachadm. 3 replies.
Page 1 of 1 (4 items)
  • 03-28-2010 3:58 AM
    • chartz
    • Top 75 Contributor
    • Joined on 07-20-2009
    • Burgundy
    • Posts 984
    • Gold Member
    Beocord 8000/9000 NOS motor sources?
    Hello to all my friends,
    I would like to know whether anyone here could indicate a source for Beocord 8000, Beocord 9000 new old stock motors. They were very high quality Matsushita ones.
    The replacement ones are not servo (tacho) controlled and they are not double-shielded like the old ones. All this affects performance of course, and noise. The single capstan arrangement was an advantage according to B&O notes, but only with those motors!
    For instance, you couldn't dectect any speed differences when winding or rewinding with the old motor. The new ones complain under the strain...
    Thanks,
    Jacques
    Jacques
  • 03-28-2010 11:59 AM In reply to
    • yachadm
    • Top 100 Contributor
    • Joined on 06-24-2007
    • Jerusalem, Israel
    • Posts 687
    Re: Beocord 8000/9000 NOS motor sources?
    Jacques
    I can rebuild yours for you if you want - I am familiar with this type.
    Menahem
    Learn from the mistakes of others - you'll not live long enough to make them all yourself!
  • 03-28-2010 12:33 PM In reply to
    • chartz
    • Burgundy
    • Posts 984
    • Gold Member
    Oh?
    What do you do exactly? Are you able to change brushes and bearings?
    Jacques
  • 03-28-2010 1:29 PM In reply to
    • yachadm
    • Jerusalem, Israel
    • Posts 687
    Anything, except rewind the armature - if that's shot, then I can't help you.
    You can test the armature windings by connecting a "ring-tester".
    Menahem
