Latest post 02-07-2010 11:59 AM by Seven. 3 replies.
Page 1 of 1 (4 items)
  • 01-22-2010 9:41 AM
    Problem with beovision-6 timerstart
    My beovision-6 26" has the timerstart feature in the menu
    Problem is when I for example set i to start next morning at 7 in the morning and shut of like 1 hour later it never starts the tv. However, if I during that hour timespan manually turn on the tv, it automatically turns off the tv right on time.
    This doesnt do me much convenience as You may guess :)
    Any ideas?
    I have the old beovision-6 with soft speaker covers
    The b&o repair shop told me that they have never ever seen anything like this and have never ever experienced a technical issue due to a electrical component causing this error so I assume I must be doing something wrong :)
  • 01-22-2010 10:32 AM In reply to
    • Seven
    • Not Ranked
    • Joined on 11-22-2008
    • Posts 35
    Re: Problem with beovision-6 timerstart
    I've got the same TV you've got. While I don't have time to test the exact same you do, I did just create two timers:
    1. turn off at a time 5 minutes in the future
    2. turn on again at a time 10 minutes in the future
    Everything worked as programmed. You could program the same thing and check if it works, too. Maybe that helps.
    Cheers
  • 01-22-2010 12:04 PM In reply to
    Thanks for the ckeckup.
    Nope It did not work like that on mine, it only shuts down on time not on. A shame I always get the odd ones when I buy my beo gear, hate the hassle of moving everything back and forth to the store.
  • 02-07-2010 11:59 AM In reply to
    • Seven
    • Not Ranked
    • Posts 35
    Sorry to hear that. Good luck with that repair!
