Hello all,
Have had the builders round who switched off the mains and therefore cut the power to the system for several hours. Subsequently the BV7 and Beocentre 2 asked for the pin which I entered correctly. The Beocentre works just fine (dispalying the radio name on the BV7 LED panel) but the BV7 fails to turn on the SkyHD box instead showing the WAIT sign for approx 2 mins then switching off.
Stuck guys and girls, what do I do?
