david coyne:
Hi
I have the same issue. I bought a nice beolit 600 off ebay from a guy in Odense, Denmark. The speaker has the same problem- is the magnet appears stuck. As a result the radio sounds very tinny.
A year has gone by, with promises to send me a new speaker. A dozen or so emails later still nothing.
Be wary of ebay I'd say.
I might try beocentral as well to see if they can help.
Regards
David Coyne
Sydney, Australia
It has nothing to do with eBay! If you had researched the subject properly you would know that many have the "stuck speaker " syndrome so you would indeed be lucky to buy one that perfomed as it should.
As I understand it, the cone surround hardens, making the whole thing less flexible and therefore unable to reproduce the low parts of the sound spectrum.
"I haven't used it for at least 5 years" followed by "It's in immaculate condition" should be your alarm signal!!
I have to admit that I fell for it with a Beolit 700 a couple of years ago. I sent it to Tim to get it fixed and still wasn't impressed with the radio. Every one I have heard of since has the same problem.
In fairness, Tim was still practising and he did make that very point which I accepted.
I was offered a red one last week which "didn't sound quite like it used to" and I was tempted until the seller told me that a previous wife had painted the panels PINK.
It is situated down in the UK West Country and if anybody wants it I can give you a contact.
If you want a Beolit for your collection then by all means go ahead, it's your money. If you want a decent radio there are loads on the market at your local Costco!!
