Latest post 01-02-2010 2:52 PM by Spiros. 3 replies.
Page 1 of 1 (4 items)
  • 01-02-2010 11:08 AM
    Beolink 3500 / LCS9000 does not respond to Beo4
    Hi there,
    I've got a problem with my old LCS 9000. I tried to connect it to my Beosystem 2 with a Mastlink cable.
    Now it does play radio when I manually switch it on, but when I try to put it on cd with my Beo4 or when I try to put it on a different radio station, it does not respond. I can't change the volume either.
    What's the problem? Oh, before I forget: the LCS 9000 does have the SW 2.0 update.
    Thanks in advance!!
  • 01-02-2010 2:10 PM In reply to
    • Spiros
    • Top 50 Contributor
    • Joined on 09-03-2007
    • Thessaloniki GREECE
    • Posts 1,088
    • Gold Member
    Re: Beolink 3500 / LCS9000 does not respond to Beo4
    Happy new year!!
    Maybe I'm wrong but the LCS9000 was not a link speaker? I think it was just used as now we are using the 7.1
    Beolab 3500 is of course a link speaker.
    Best regards
    Spiros
  • 01-02-2010 2:28 PM In reply to
    hi and thanks for your answer! And a happy new year to you too!
    The LCS9000 is actually the same speaker with the same looks as the Beolab 3500.
    Also it has both a ML and MCL connection. It has had the 2.0 software update which should make it function exactly the same as the BL3500.
    LCS is just an early version of the BL3500.
  • 01-02-2010 2:52 PM In reply to
    • Spiros
    • Posts 1,088
    • Gold Member
    As I told you. Maybe I'm wrong on this Smile
    Best regards
    Spiros
