Latest post 04-20-2010 4:23 AM by david707. 5 replies.
Page 1 of 1 (6 items)
  • 04-19-2010 5:51 AM
    1611 converter
    Is it possible to use two 1611 converters in the same setup? I propose to use BV7mk2>1611>BC9500>MCL Xtra TV>1611>Avant 32 DVD.
    The PCG does not list the Avant as a possible link TV when using the MCL system.
    David
  • 04-19-2010 12:55 PM In reply to
    Re: 1611 converter
    Probably not!
    the more " obvious" connections would be:
    BV7>ml>Avant
          >ml>1611>BC9500
  • 04-19-2010 3:01 PM In reply to
    • stefan
    • Top 50 Contributor
    • Joined on 04-16-2007
    • 200 miles from Struer
    • Posts 1,733
    Re: 1611 converter
    david707:
    David
    Interesting. I assume you want to integrate local audio sources in the link room..(?) I dont know why it should not work. I had a mixed ML / MCL system with a 1610 converter and a BL video years ago.
    Stefan
  • 04-19-2010 4:28 PM In reply to
    Re: 1611 converter
    I can integrate a local audio source in the link room but don't use that facility.  I have Avant 32 DVD>1611>BC9500>MCL>Xtra TV>LX5500 and it all works well. (why change it??)  I would use the Avant in the link room with a BV7 (or BV10) as master but retaining the MCL as it would be difficult to re-wire.
    David
  • 04-19-2010 4:44 PM In reply to
    • stefan
    • Posts 1,733
    Re: 1611 converter
    Ok. If you can set the Avant to V.OPT 6 it should work. So I would check it out. Good luck.
    Stefan
  • 04-20-2010 4:23 AM In reply to
    Re: 1611 converter
    Thanks Carolpa & Stefan for the helpful replies.
    David
