Latest post 05-12-2010 8:31 AM by RENATO. 2 replies.
Page 1 of 1 (3 items)
  • 03-23-2010 1:37 AM
    dvd 1
    hi  I just bought a dvd1  from europe and iwould like to know which remote control i need to used it  i have master control panel 6500 any chance it works with that or do i have to buy another  model  and i don't have a  bang and olufsen t.v  can i use it  without a bang tv i got a video projector  any chance it woks with that thanks
    Filed under:
  • 03-23-2010 2:50 AM In reply to
    Re: dvd 1
    The DVD1 needs a TV set with Datalink to work by remote. There is no IR receiver in it. You need a Beolink 1000 or Beo4 but you also need the TV!
  • 05-12-2010 8:31 AM In reply to
    • RENATO
    • Not Ranked
    • Joined on 05-10-2010
    • ITALY
    • Posts 7
    Re: dvd 1
    thanks for so clear information!!
    it was an hour ,or so, that I was looking how to operate my dvd1 asa cd player ,with a beolink 1000, it's just not possible!
